How To Test Card Dialogic ?
Hi.
I have a card dialogic D/300PCI-E1, please help me how to test D/300PCI-E1 work? I had setup voiceguide v7.
Are you sent my mail adrress: huuphuc1976@yahoo.com.vn? Thanks.
The Dialogic card needs to be tested with Dialogic's ISDIAG test tool to confirm it is working on your E1. Once the card is working you can then install VoiceGuide and start using it.
We do offer and installation service. Please contact sales@voiceguide.com for details.
Dear Sir
I had run ISDIAG, no error but not receive signal from line E1.
Please help me.
My Bpx: Alcaltel Ommi OXO
Protocol: QSIG
What does ISDIAG show? Please post some screenshots.
We also offer an installation service where we can log into the system and do the Dialogic card testing and installation. Please contact sales@voiceguide.com for pricing.
Screenshot shows the D channel on the ISDN line is OK. You should now be able to try placing some calls into the system and use ISDIAG to answer the call.
You could also start the ISDN level trace.
It's best to start a trace then place a call into the system and then answer the cal and then hangup. Then save the ISDN trace and have a look at it (or post it here) to make sure all is OK. Once ISDIAG shows all is OK you can start VoiceGuide and start using VoiceGuide to receive and make calls.
Trace shows the ISDN's D channel is working fine and the incoming call's SETUP messages can be seen in it.
Did you try answering the incoming call using ISDIAG?
When you just start VoiceGuide v7 now and place a call into the system what happens?
Please post VoiceGuide's ktTel trace which captures the incoming call. ktTel trace is created in VoiceGuide's \log\ subdirectory.
I attach the trace translated using Dialogic's ISDTRACE.EXE utility.
trace.txt
Looking at the System Status screenshot we can see that you have not changed VoiceGuide's Config.xml file to match the Dialogic card which you are using.
VoiceGuide by default installs the Config.xml file for a 4 line analog card, and you want the 30 line ISDN version of the Config.xml
Do this:
1. Stop VoiceGuide.
2. Go to VoiceGuide's \Config\ subdirectory.
3. Rename "Sample Config for 30 ports using one E1 ISDN.xml" to "Config.xml" (overwrite previous Config.xml)
4. Start VoiceGuide.
Make another call into system after VoiceGuide is started.
post ktTel trace capturing incoming call.
Trace shows that the VoiceGuide starts the Dialogic card OK, and all the 30 channels on the card are opened and unblocked.
But no calls are reported by the Dialogic card.
Are you using the latest SR6.0 Dialogic drivers?
What ISDN protocol have you selected for this card?
Which Telco or Switch/PBX supplies this E1? What is the protocol name/spec that that is configured on that Switch/PBX?
Dear sir
[Are you using the latest SR6.0 Dialogic drivers?]
I using System Release 5.1.1 FP1 Service Update 148, because SR6.0 Dialogic drives not support D/300PCI-E1 card.
[What ISDN protocol have you selected for this card?]
ISDN protocol: QSIG / QTE
[Which Telco or Switch/PBX supplies this E1? What is the protocol name/spec that that is configured on that Switch/PBX?]
I use PBX Alcatel OXO, connect with Dialogic card via E1 DLT2 Card (QSIG protocol)
Are there any other ISDN protocol options available on the PBX apart from QSIG?
If not then do you have a chance to try the setup with the D/300JCT card (and SR6.0)?
You can probably obtain the D/300JCT card form your Dialogic supplier on a trial basis to see if this card along with SR6.0 will connect to Alcatel's QSIG properly.
Thank for the reply.
ISDN protocol's Alcaltel: QSIG only.
I will retry
Thank you very much.
Trace shows VoiceGuide is issuing commands for the Dialogic card to Accept and Answer the call, but immediately after issuing the Answer command the Dialogic drivers respond that the call is DISCONNECTED
There is really not much that we can do about this. The card which you are trying to use is old and the drivers have already been discontinued, so this product is not supported by Dialogic any more.
Recommend you change to a D/300JCT card and use the current release SR6.0 drivers.
0212:
133050.279 1368 002 ev GCEV_DETECTED crn=0x0=0 {2:crn_set}
133050.279 1368 002 CtEventProcess (from store) idx=32, iDev=2, lEvtType=2084, pEvtData=0x6d36f38, lEvtDataLen=28, (store: evinque=0, maxever=1)
133050.279 1368 002 ev GCEV_OFFERED crn=0x2008001=33587201 (ktTel_SR60 v7.0.5, Feb 26 2008 16:17:15) {2:crn_set}
133050.279 1368 002 calling CIPStateMachine_NullGcevOffered next
133050.279 1368 002 raising LINECALLSTATE_OFFERING next
133050.279 1368 002 CTelProxy::Event_CallState m_pTelProxyClient=0078146C
133050.279 1368 002 raise CallState LINECALLSTATE_OFFERING
133050.340 1368 002 calling OnOffered_GetCallerID next
133050.340 1368 002 OnOffered_GetCallerID start (with CallerID report)
133050.340 1368 002 OnOffered_GetCallerID gc_GetCRN: crn=0x2008001=33587201 {2:crn_set}
133050.350 1368 002 could not retrieve CALLNAME
133050.350 1368 002 CTelProxy::Event_CallerId begin. name=, nbr=123, dnis=102
133050.360 1368 002 raise CallerId
133050.390 1368 002 fn LineAnswerCall(sXMLOptions=[])
133050.400 1368 002 gc_AcceptCall crn=0x2008001=33587201
133050.400 1368 002 CTelProxy::Event_CallerId end
133050.400 1368 002 CtEventProcess (from store) idx=33, iDev=2, lEvtType=2052, pEvtData=0x6d36f68, lEvtDataLen=28, (store: evinque=0, maxever=1)
133050.400 1368 002 ev GCEV_ACCEPT crn=02008001=33587201
133050.400 1368 002 CTelProxy::Event_CallState m_pTelProxyClient=0078146C
133050.400 1368 002 raise CallState LINECALLSTATE_ACCEPTED
133050.400 1368 002 IssueAnswerCallAfterReceivingAcceptedEvent=true
133050.400 1368 002 gc_AnswerCall crn=02008001=33587201
133050.430 1368 002 CtEventProcess (from store) idx=34, iDev=2, lEvtType=2086, pEvtData=0x6d36f98, lEvtDataLen=28, (store: evinque=0, maxever=1)
133050.430 1368 002 ev GCEV_DISCONNECTED crn=02008001=33587201
133050.440 1368 002 GCEV_DISCONNECTED : gcValue=68(0x44), gcMsg=[invalid parameter], ccLibId=2, ccLibName=[GC_ISDN_LIB], ccValue=0x38a, ccMsg=[bad input parameter], additionalInfo=[]
133050.440 1368 002 raise Dialogic GCEV_DISCONNECTED 2086 (2086 0 0 )
0215:
094901.654 2540 002 ev GCEV_DETECTED crn=0x0=0 {2:crn_set}
094901.654 2540 002 CtEventProcess (from store) idx=32, iDev=2, lEvtType=2084, pEvtData=0x6d36f38, lEvtDataLen=28, (store: evinque=0, maxever=1)
094901.654 2540 002 ev GCEV_OFFERED crn=0x200803f=33587263 (ktTel_SR60 v7.0.5, Feb 26 2008 16:17:15) {2:crn_set}
094901.654 2540 002 calling CIPStateMachine_NullGcevOffered next
094901.654 2540 002 raising LINECALLSTATE_OFFERING next
094901.654 2540 002 CTelProxy::Event_CallState m_pTelProxyClient=0078146C
094901.664 2540 002 raise CallState LINECALLSTATE_OFFERING
094901.724 2540 002 calling OnOffered_GetCallerID next
094901.724 2540 002 OnOffered_GetCallerID start (with CallerID report)
094901.724 2540 002 OnOffered_GetCallerID gc_GetCRN: crn=0x200803f=33587263 {2:crn_set}
094901.724 2540 002 could not retrieve CALLNAME
094901.724 2540 002 CTelProxy::Event_CallerId begin. name=, nbr=123, dnis=300
094901.724 2540 002 raise CallerId
094901.764 2540 002 fn LineAnswerCall(sXMLOptions=[])
094901.774 2540 002 gc_AcceptCall crn=0x200803f=33587263
094901.774 2540 002 CTelProxy::Event_CallerId end
094901.795 2540 002 CtEventProcess (from store) idx=33, iDev=2, lEvtType=2052, pEvtData=0x6d36f68, lEvtDataLen=28, (store: evinque=0, maxever=1)
094901.795 2540 002 ev GCEV_ACCEPT crn=0200803F=33587263
094901.795 2540 002 CTelProxy::Event_CallState m_pTelProxyClient=0078146C
094901.795 2540 002 raise CallState LINECALLSTATE_ACCEPTED
094901.795 2540 002 IssueAnswerCallAfterReceivingAcceptedEvent=true
094901.795 2540 002 gc_AnswerCall crn=0200803F=33587263
094901.815 2540 002 CtEventProcess (from store) idx=34, iDev=2, lEvtType=2086, pEvtData=0x6d36f98, lEvtDataLen=28, (store: evinque=0, maxever=1)
094901.815 2540 002 ev GCEV_DISCONNECTED crn=0200803F=33587263
094901.815 2540 002 GCEV_DISCONNECTED : gcValue=68(0x44), gcMsg=[invalid parameter], ccLibId=2, ccLibName=[GC_ISDN_LIB], ccValue=0x38a, ccMsg=[bad input parameter], additionalInfo=[]
094901.815 2540 002 raise Dialogic GCEV_DISCONNECTED 2086 (2086 0 0 )
094901.815 2540 002 CTelProxy::Event_CallState m_pTelProxyClient=0078146C
094901.815 2540 002 raise CallState LINECALLSTATE_DISCONNECTED
Dear sir,
Would you please help me to solve this problem, we already bought the D/300 SC and D/300 PCI card, but we do not have the D/300JCT. Please also advice us why the Dialogic drivers response disconnected instead of answering the call.
What will i need to check out to fix this problem. We are planning to use you VoiceGuide for this project and can not stop it now.
Thank you for your supports.
Try using the D/300 PCI card and setting up the SR 5.1.1 drivers on it, then test teh card using the Dialogic's ISDIAG test application.
The ISDIAG will let you accept incoming calls and answer them.
Once ISDIAG is working try installing VoiceGuide v6 and see if calls get answered with v6
Trace shows that the Dialogic drivers are reporting a GCEV_DISCONNECTED immediately after the incoming call has been 'Accepted'.
This is the same as what the previous traces where showing.
Have you tried testing with ISDIAG to see if ISDIAG can answer incoming calls?
Does your PBX offer other ISDN protocols other then QSIG? If it does then please try using them to see if the Dialogic card/drivers can work with your /PBX using another ISDN protocol.
Apart form the above the only other option is to get a D/300JCT from your local distributor and setup this system with the current SR6.0 drivers.
090043.343 002 ev GCEV_OFFERED (ktTelControl v2.4.5, Mar 30 2008 13:04:46)
090043.343 002 could not retrieve CALLNAME
090043.343 002 ocxev CallerId(sLineId=2, hCall=0(0x0), crn=33587203(0x2008003) strCallerID=[122], strName=[], strDialed=[300])
090043.343 002 ocxev DoFireDialogic(dwIdx=4, 2, 2084, [GCEV_OFFERED], 2084, 0, 0, [], [], []) (dwIdx=4)
090043.343 002 gc_CallAck(crn=33587203(0x2008003), 0x8e5bfbc GCACK_SRVICE_PROC, EV_ASYNC) call
090043.343 002 eng gc_GetMetaEventEx returned. lEvtHandle=0, iDev=2, lEvtType=2150, pEvtData=0xe6b31c8, lEvtDataLen=28
090043.343 002 ev metaevent: cclibid=0x2, crn=0x2008003, evtdatap=0xe6b31c8, evtdev=0x2, evtlen=0x1c, evttype=0x866, extevtdatap=0x0, flags=0x1, linedev=0x2, magicno=0xbad012fb, rfu1=0x2, usrattr=0x1e2d78 (usrattr=hli)
090043.343 002 ev GCEV_CALLPROC (2150) has no handler
090043.343 002 ocxev DoFireDialogic completed
090043.343 002 te LINE_CALLSTATE(2, 0x2, 0x2, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_OFFERING
090043.343 002 eng gc_GetMetaEventEx returned. lEvtHandle=0, iDev=2, lEvtType=2049, pEvtData=0xe6b7168, lEvtDataLen=28
090043.343 002 ev metaevent: cclibid=0x2, crn=0x2008003, evtdatap=0xe6b7168, evtdev=0x2, evtlen=0x1c, evttype=0x801, extevtdatap=0x0, flags=0x1, linedev=0x2, magicno=0xbad012fb, rfu1=0x2, usrattr=0x1e2d78 (usrattr=hli)
090043.343 002 ev GCEV_TASKFAIL
090043.343 002 gc_GetCallState(crn=33587203)
090043.343 002 ev OnFireCallerIdArrived (hli=0x1e2d78) (122,,300)
090043.343 002 callstate=[GCST_CALLROUTING]
090043.343 002 gc GCEV_TASKFAIL status gc:68:[invalid parameter], cc_err=906 cclibid=2
090043.343 002 ResultInfo gcValue=137(0x89) gcMsg=[CCLIB specific] ccLibId=2 ccLibName=[GC_ISDN_LIB] ccValue=[0x11f|EGC_CCLIBSPECIFIC|cclib specific - a catchall] ccMsg=[bad message in service/feature provided] additionalinfo=
090043.343 not calling ResetLineDev
090043.343 002 ocxfn LineAnswer(lLineId=2, lParam=0, strParam=)
090043.343 gc_AcceptCall(33587203(0x2008003), 0, EV_ASYNC) ok
090043.359 002 eng gc_GetMetaEventEx returned. lEvtHandle=0, iDev=2, lEvtType=2052, pEvtData=0xe6b7168, lEvtDataLen=28
090043.359 002 ev metaevent: cclibid=0x2, crn=0x2008003, evtdatap=0xe6b7168, evtdev=0x2, evtlen=0x1c, evttype=0x804, extevtdatap=0x0, flags=0x1, linedev=0x2, magicno=0xbad012fb, rfu1=0x2, usrattr=0x1e2d78 (usrattr=hli)
090043.359 002 ev GCEV_ACCEPT
090043.390 002 eng gc_GetMetaEventEx returned. lEvtHandle=0, iDev=2, lEvtType=2086, pEvtData=0xe6b31c8, lEvtDataLen=28
090043.390 002 ev metaevent: cclibid=0x2, crn=0x2008003, evtdatap=0xe6b31c8, evtdev=0x2, evtlen=0x1c, evttype=0x826, extevtdatap=0x0, flags=0x1, linedev=0x2, magicno=0xbad012fb, rfu1=0x2, usrattr=0x1e2d78 (usrattr=hli)
090043.390 002 ev GCEV_DISCONNECTED
090043.390 002 gc GCST_DISCONNECTED status gc:68:[invalid parameter], cc_err=906 cclibid=2
090043.390 002 ResultInfo gcValue=1280(0x500) gcMsg=[Normal completion] ccLibId=2 ccLibName=[GC_ISDN_LIB] ccValue=[0x210|GCRV_NORMAL|normal completion ] ccMsg=[Normal clearing] additionalinfo=
090043.390 003 dx_stopch call in GCEV_DISCONNECTED
090043.390 003 dx_stopch 3 ok
090043.390 002 gc gc_DropCall(crn=33587203, GC_NORMAL_CLEARING) (on Disconnected event)
090043.390 002 gc gc_DropCall ok
Dear sir
How to test with ISDIAG to see if ISDIAG can answer incoming calls?
Please help me.
Dear Sir.
How to configuration parameter for D/300PCI E1 Dialogic card? (Files: TSFFileName?, ISDNProtocol: Value ?, Misc:FirmwareFile ?, ParameterFile ?, TSFFileSupport ?, DisconnectTone ?,...)
Please help me. Thank you for your supports.
The only parameter you need top set is the ISDNProtocol. Leave all other settings blank.
Have you set the ISDNProtocol parameter before?
In your case it needs to be set to "QTE" if the Dialogic card is to function in "User Side" mode, and set it to "QNT" if the Dialogic card is to function in "Network Side" mode.
The PBX is most likely functioning in "Network Side" mode, so the Dialogic card should be set in "User Side" mode.
Set "Country" to US.
Just type *.vox into the "Filename" text box, press Enter and the .vox files will be displayed.
Or just specify the fill path to the .vox file directly in the Module's property pages without using the "Select File" dialog.
Did you successfully configure the Dialogic card to receive calls? What settings did you use?
Dear Sir
I do not successfully configure the Dialogic card to receive calls. It's worth a try.
Dear Sir.
I don't have D/300JCT card.
D/300PCI E1 support ISDN protocol QSIC-BC (Basic call)?
Please help me.
The documentation for the SR5.1.1 drivers that you are using should list the various protocols supported.
From memory I think it was QTU for QSIG protocol working in User Side mode, and QTN (or QNT?) for QSIG protocol working in Network Side mode.
We offer an remote installation service where we will configure the Dialogic card for you and install the and configure the VoiceGuide software. For more details about the installation service please contact sales@voiceguide.com directly.
