Maciej Zasadzki ADVICOS Report post Posted 02/13/2026 11:02 AM I need assistance. In the Status Monitor window, the error "Function not supported in the current state (invalid state)" appears, and this same message is in the logs. Please advise how to eliminate this issue, as this state fully blocks the port and does not release it. Of course, the phone numbers have been anonymized. Quote 114121.270 20 14 4 6746 Issue_MakeCall begin 114121.270 20 14 4 6746 L1_set Dialing (iScriptState=LS_NULL_AWAITINGCALLS) 114121.270 20 14 4 6746 L2_set Setup_Dialing (Issue_MakeCall) 114121.270 20 14 4 6746 rvns add OutDial_Result|NOTCONTACTED 114121.270 20 14 4 6746 Issue_MakeCall sKtTel_and_Dialogic_Level_DialoutOptions <DX_CAP> not set. example <DX_CAP>: <DX_CAP><ca_cnosig>1600</ca_cnosig><ca_pamd_failtime>300</ca_pamd_failtime></DX_CAP> 114121.270 20 14 4 6746 ktTel_MakeCall_Enqueue([###########],CONNECT_IMMEDIATELY, 60,0,38,#########,<calltype>DialAndConf</calltype><CallerId>#########</CallerId><RV>[CDR_user]{ID20260213_114115_200_12_50011}</RV>) call 114121.271 20 14 4 6746 q_tel + cmd_MakeCall 0 [] [0,38,60,0,0,0,0,0][#########|<calltype>DialAndConf</calltype><CallerId>#########</CallerId><RV>[CDR_user]{ID20260213_114115}</RV>|###########|CONNECT_IMMEDIATELY||||] 114121.271 20 14 4 6746 rvns add other_leg_outdial_result|NOTCONTACTED 114121.271 21 14 4 6746 q_tel run cmd_MakeCall 0 0 [] 0 max:1|1,0576 114121.271 20 38 12 6744 t timer set 3600 sec : EV_TIMEOUT_HANGUP 114121.271 20 14 4 6746 t timer set 3600 sec : EV_TIMEOUT_HANGUP 114121.272 20 14 4 6746 rv add CDR_user|ID20260213_114115_200_12_50011 114121.272 20 38 12 6744 xfer blind single_xfer isdn_voip bridge_now state_7 114121.272 20 38 12 6744 TwoCalls_Bridge 38<=>14 114121.272 20 38 12 6744 TwoCalls_Bridge (dtiB1T12<=>dtiB1T4) 114121.272 34 14 4 6746 ev ktTel_Completion (genericEv) 10000 0,Completion_MakeCall, crn=ffffffff, -1,0,0,###########,#########,Function is not supported in the current state|Invalid state 114121.272 20 38 12 6744 TwoCalls_Bridge crnThatCreatedConfBinding set to crn_CurrentConnected 6030026 114121.273 20 14 4 6746 TwoCalls_Bridge crnThatCreatedConfBinding set to crn_CurrentMakeCallAttempt 1 114121.273 34 14 4 6746 q_scr + evktTelCompletion lcode=0 scode=[Completion_MakeCall] 114121.273 20 38 12 6744 rvns add TsRoutedTo|14 114121.273 20 14 4 6746 rvns add TsRoutedTo|38 114121.273 20 14 4 6746 rvns add Conf_DevName_1|dtiB1T12 114121.273 20 14 4 6746 rvns add Conf_LineId_1|38 114121.273 20 14 4 6746 rvns add Conf_LineNbr_1|12 114121.273 20 14 4 6746 rv add Conf_DevName_2|dtiB1T4 114121.274 20 14 4 6746 rv add Conf_LineId_2|14 114121.274 20 14 4 6746 rv add Conf_LineNbr_2|4 114121.274 20 38 12 6744 rvns add Conf_DevName_1|dtiB1T12 114121.274 20 38 12 6744 rvns add Conf_LineId_1|38 114121.274 20 38 12 6744 rvns add Conf_LineNbr_1|12 114121.275 20 38 12 6744 rv add Conf_DevName_2|dtiB1T4 114121.275 20 38 12 6744 rv add Conf_LineId_2|14 114121.275 20 38 12 6744 rv add Conf_LineNbr_2|4 114121.275 20 38 12 6744 rv add Conf_ConnectedToNumber|########### 114121.276 20 38 12 6744 rvns add Transfer Call_DevName_1|dtiB1T12 114121.276 20 38 12 6744 rvns add Transfer Call_LineId_1|38 114121.276 20 38 12 6744 rvns add Transfer Call_LineNbr_1|12 114121.276 20 38 12 6744 rv add Transfer Call_DevName_2|dtiB1T4 114121.276 20 38 12 6744 rv add Transfer Call_LineId_2|14 114121.276 20 38 12 6744 rv add Transfer Call_LineNbr_2|4 114121.309 20 38 12 6744 rv add Transfer Call_ConnectedToNumber|########### 114121.309 20 38 12 6744 q_tel + cmd_TsRoute 0 [] [0,0,0,0,0,0,0,0][dtiB1T12||dtiB1T4||SC_FULLDUP|||] 114121.310 20 14 4 6746 state from iLineId : vgmidx=678, strVgmTitle=Transfer Call 114121.310 21 38 12 6744 q_tel run cmd_TsRoute 0 0 [] 1 max:1|1,0576 114121.310 20 38 12 6744 state [Transfer Call] in_leg 12 <=> 4 ########### | 114121.310 20 14 4 6746 state [Transfer Call] out_leg 12 <=> 4 ########### | Share this post Link to post
SupportTeam Report post Posted 02/13/2026 11:09 PM Please post the ktTel trace excerpt for that time and also includes the previous call on that channel (port 4 / lineid 14). We can then see what is happening on the system and advise. Please .ZIP up any traces before posting. Share this post Link to post
