TomP Report post Posted 01/28/2026 01:10 PM Hello VoiceGuide Team, Unfortunately, we have an error in our call routing process. Directly at the beginning after the greeting, a PIN should be requested, unfortunately no input time is waited here, so a second process is started immediately. In the second run, an input is then waited for... as it should be. Unfortunately, we can't find the error here and would like to kindly ask if you might see something we don't. I have attached the script once. Wachobjekt.vgs Share this post Link to post
SupportTeam Report post Posted 01/28/2026 10:07 PM Can you please post the VgEngine file capturing the incoming call. We can the see what has happened on the call and advise. Most likely the issue here is that you have "Do not wait for VBScript to complete" option selected in the previously executed "CheckRufnummer" module, but that module's VBScript is also calling the "Run_ResultReturn" API. The "Run_ResultReturn" API tells VoiceGuide's callflow executing engine to take a specific path out of the current module. So if that current module happens to be "PINEingabe" when the VBScript started by the "CheckRufnummer" module completes, then a path out of that "PINEingabe" module will be taken as the effect of that "Run_ResultReturn" API call... Resolution would be to change the "CheckRufnummer" module's setting to be "Wait until VBScript completes" (or remove the "Run_ResultReturn" API call). Changing that module's setting to be "Wait until VBScript completes" looks to be the right thing to do, as that module is querying a database, and we can see that you have specified the following path to be taken in case the database query is taking too long: on {timeout 5} goto [DB-Fehler] and above timeout path will only be in force while the callflow is in that module. Share this post Link to post
TomP Report post Posted 01/29/2026 03:54 PM Hello VoiceGuide Team, Attached you will find the vgEngine file and the call events, in which several incoming calls should be visible. If you could briefly confirm, based on these, whether the issue can indeed be resolved by changing the settings of the “Check Rufnummer” module to “Wait until VBScript completes”, I would test this and provide feedback. Many thanks in advance! 0129_1546_vgEngine.txt 0129_CallEvents.txt Share this post Link to post
SupportTeam Report post Posted 01/29/2026 08:25 PM Trace confirms that "Run_ResultReturn" call from module [CheckRufnummer] is whats causing VoiceGuide to exit [PINEingabe] and take "success" path to module [PINVergleich]. 154711.507 17 3 1 1 state [CheckRufnummer] RunScript (no wait) | 154711.508 17 3 1 1 modvbs QueueUserWorkItem vbScript 154711.508 17 3 1 1 modvbs check for success path 154711.508 17 3 1 1 find_next_vgm module=[AnzahlPINVersuche] (trigger={SUCCESS}) 154711.508 17 3 1 1 t timer clear force=False(RunModule_begin) 154711.508 17 3 1 1 RunModule start Evaluate, [AnzahlPINVersuche], vgm=10, previous_vgm=2 154711.508 17 3 1 1 state [AnzahlPINVersuche] Evaluate [0] | ... 154711.509 17 3 1 1 RunModule start Get Numbers, [PINEingabe], vgm=60, previous_vgm=10 154711.509 17 3 1 1 state [PINEingabe] Number Input | 154711.510 17 3 1 1 PrepareAndPlayWavAndTts start iModuleIdx=60, iPlayFileIdx=1, bMakeTtsFile=True, sSoundFileIs= 154711.510 17 3 1 1 rv replace start [$RV[ScriptPath]\WOAnsagePINEingabe.wav] 154711.510 17 3 1 1 rv replace end [C:\INSOCAM\\WOAnsagePINEingabe.wav] 154711.510 17 3 1 1 PrepareAndPlayWavAndTTS sPlayFile=C:\INSOCAM\\WOAnsagePINEingabe.wav 154711.511 17 3 1 1 state [PINEingabe] Playing wav (C:\INSOCAM\\WOAnsagePINEingabe.wav) | 154711.511 17 3 1 1 PlayStartOrFireEventFinished strSndFile: C:\INSOCAM\\WOAnsagePINEingabe.wav ... 154711.514 12 3 1 1 task scr Run_VBS vgm=2, file=, RunUsingClearScript=True 154711.514 12 3 1 1 state [CheckRufnummer] Run Script vbs, onhold= | 154711.514 12 3 1 1 rv replace start - not logging - input length is >1000 ... 154711.518 12 3 1 1 scr ClearScript VBS engine used 154711.519 12 3 1 1 scr ClearScript VBS new VBScriptEngine completed 154711.519 12 3 1 1 scr ClearScript VBS AddHostObject vg completed 154711.519 12 3 1 1 scr .Execute call 154711.544 3 api vgServices_CommandLink started 154711.547 3 3 1 1 api RvSet RV_ErkannteNummer, 491703480746 154711.547 3 3 1 1 rv add RV_ErkannteNummer|491703480746 154711.548 3 3 1 1 api RvSet RV_OTID, 31759 154711.548 3 3 1 1 rv add RV_OTID|31759 154711.548 3 3 1 1 api RvSet RV_VLID, 46417 154711.548 3 3 1 1 rv add RV_VLID|46417 154711.549 3 3 1 1 api Run_ResultReturn success 154711.549 3 3 1 1 q_scr + cmdRun_ResultReturn lcode=0 scode=[] 154711.549 17 3 1 1 q_scr run cmdRun_ResultReturn 0 action_id=0, crn=0 [0|0|0|0|0][success|||||] 00:00:00 max:1|0,4942 154711.549 12 3 1 1 scr dispose call 154711.550 12 3 1 1 scr sModuleType=Run VB Script 154711.550 12 3 1 1 scr .Execute returned. iRunWait=0 154711.550 12 3 1 1 scr wait=0. exiting thread 154711.551 17 3 1 1 Run_ResultReturn_InqScr keyword return - iRunWait_VgmIdx not set 154711.552 17 3 1 1 rv add PINEingabe_ResultReturn|success 154711.552 17 3 1 1 path {success} found (at offset 70) 154711.552 17 3 1 1 find_next_vgm module=[PINVergleich] (trigger={success}) 154711.552 17 3 1 1 Run_ResultReturn_InqScr state: .iRunWait_VgmIdx=-1, iVgmIdx=60 154711.552 17 3 1 1 t timer clear force=False(RunModule_begin) 154711.552 17 3 1 1 RunModule start Run VB Script, [PINVergleich], vgm=11, previous_vgm=60 154711.552 17 3 1 1 state [PINVergleich] RunScript | Share this post Link to post
TomP Report post Posted 02/16/2026 03:24 PM The change in the script as described has resolved the error; the faulty announcement no longer occurs. Thank you very much! Share this post Link to post
