Improving speech recognition and TTS handling in VoiceGuide
I have two questions:
  1. I have a question regarding the parameter SAPI_TTS_Speed. Specifically:
    Does this parameter work when using the Google Cloud TTS engine (EngineType=Google) within VoiceGuide, or is it only applicable when using a SAPI-compatible TTS engine?
    Can the SAPI_TTS_Speed parameter be modified dynamically (for example, as a variable in Evaluate Expression), or can it only be changed statically in the VG.ini file?
  2. Would it be possible, for simplifying the call flow, to enable the ASR_NLP parameters directly in the Play module — instead of having to add in a separate Evaluate Expression module variable ASR_NLP_PlayModuleName?
Thank you in advance for your help.
SAPI_TTS_Speed is a setting that can be used on some SAPI engines. it does not affect Google Cloud TTS  generation. There is no option to modify it midway through callflow.
A Play module in VoiceGuide v7 and prior does have functionality to set parameters. A Run Script module can be used to set multiple parameters in VoiceGuide v7 and prior - using the RvSet and RvSet_RvList API calls.
https://www.voiceguide.com/vghelp/source/html/com_rvset.htm
https://www.voiceguide.com/vghelp/source/html/com_rvset_rvlist.htm
