detect suddenly hang up the call
I would like to ask can VoiceGuide detect suddenly hang up the call, when a caller use the callflow? I want to use vb script to put it in text file?
Thank you. I would like to ask can any result Variable can store the caller use the modules in callflow  before detect suddenly hang up the call? It is because I need to write in a text file.
Thank you. But how I do it? Can you provide me an example of Result Variables from the script which was handling the call are available to the 'Cleanup' script ?
In the VoiceGuide callflows that you posted here: https://www.voiceguide.com/forums/topic/13192-vb-script-cant-go-to-next-script/
The Get Numbers type module that is titled "GetMemberId" will store the number entered by caller in this $RV:
$RV[GetMemberId]
So you can use that $RV in any callflow that runs for the remainder of the call, and during the "After-Hangup" callflow.
I see that you are already using that $RV to retrieve data from a database in module "ValidMemberID", using this SQL query:
SELECT member_id FROM basic_info WHERE member_id='$RV[GetMemberId]'
Using that $RV in the After-Hangup" callflow would be no different then using in in calflows that are ran while the call is still connected.
