Can I send SMS message to Phone (Variable)
Most common way of achieving this is to use a "Send Email" module to send an email to the email->sms service/gateway.
There are many of these services. Google "Email to SMS" to find one in your area.
If you know the mobile network that the phone is on then you can usually just send email to that network operators email->sms gateway for free.
Alternative approach for remote sites with no internet connection is to attach a GSM modem to the server and issue SMS send command to it using a "Run Program" module.
Dear Sir
I have already make attendence  script to record the attendence  for remote site staffs
 But How to send email or SMS to the confirm with each staffs  who just take attend (evidence)
Dear Sir
I use below VBscript to add new record of IVRattenednece .txt ,
how to send mail with last record using Email modules ?
Const ForReading = 1
Const ForWriting = 2
Const ForAppending = 8
set fso = CreateObject("Scripting.FileSystemObject")
set tsFile = fso.OpenTextFile("c:\Program Files\VoiceGuide\Scripts\Meter Reading\IVRattendence.txt", ForAppending, True)
If $RV_HH > 12 Then
  ihh =right("0" &cstr($RV_HH - 12),2)
  tsFile.WriteLine "20$RV_YY/$RV_MM/$RV_DD PM " & ihh & ":$RV_NN:$RV_SS" & vbTab & "$RV_CIDNUMBER" & vbTab & "$RV[GetID]"
Else
    If $RV_HH = 12 Then
           tsFile.WriteLine "20$RV_YY/$RV_MM/$RV_DD PM " & 12 & ":$RV_NN:$RV_SS" & vbTab & "$RV_CIDNUMBER" & vbTab & "$RV[GetID]"
     Else
          tsFile.WriteLine "20$RV_YY/$RV_MM/$RV_DD AM $RV_HH:$RV_NN:$RV_SS" & vbTab & "$RV_CIDNUMBER" & VbTab & "$RV[GetID]"
    End If
End If
tsFile.Close
set tsFile = Nothing
set fso = Nothing
Here is one way:
Change your script to this:
If $RV_HH > 12 Then
  sDetails = "20$RV_YY/$RV_MM/$RV_DD PM " & ihh & ":$RV_NN:$RV_SS" & vbTab & "$RV_CIDNUMBER" & vbTab & "$RV[GetID]"
Else
  If $RV_HH = 12 Then
    sDetails = "20$RV_YY/$RV_MM/$RV_DD PM " & 12 & ":$RV_NN:$RV_SS" & vbTab & "$RV_CIDNUMBER" & vbTab & "$RV[GetID]"
  Else
    sDetails = "20$RV_YY/$RV_MM/$RV_DD AM $RV_HH:$RV_NN:$RV_SS" & vbTab & "$RV_CIDNUMBER" & VbTab & "$RV[GetID]"
  End If
End If
tsFile.WriteLine sDetails
tsFile.Close
set fso = Nothing
vg.RvSet $RV_LINEID, "logged_details", sDetails
vg.Run_ResultReturn $RV_LINEID, "Success"
set vg = Nothing
and then in Send Email module you can use this $RV:
$RV[logged_details]
as part of the body of the email message sent.
Dear Sir
I don' t know where the location of code put in my script ?
set vg = Nothing
Version=7.0
DefaultModuleDisplayHeight=
StartModule=Check Caller ID
RunAtHangup=
StartWithoutAnswer=1
CtmAsiName=
[Get Lang]
Type=Play
DispSize=69
Txt="Welcome hotline.  For Cantonese, please press 1.  For English, please press 3."
PlayFile1=get lang.wav
Replay=0,1
strTtsText=
on {1} goto [GetID]
on {2} goto [GetID]
on {3} goto [GetID]
on {4} goto [GetID]
on {5} goto [GetID]
on {6} goto [GetID]
on {7} goto [GetID]
on {8} goto [GetID]
on {9} goto [GetID]
on {0} goto [GetID]
Position=233,115
[GetID]
Type=Get Numbers
DispSize=69
Txt=Beep and get worker ID.
PlayFile1=C:\Program Files\VoiceGuide\Scripts\Meter Reading\playSTD.wav
PlayFile2=C:\Program Files\VoiceGuide\Scripts\Meter Reading\saystd.wav
PlayFile3=C:\Program Files\VoiceGuide\Scripts\Meter Reading\confirm_1.wav
PlayFile4=C:\Program Files\VoiceGuide\Scripts\Meter Reading\Playswrong.wav
Replay=10,4
GetNbrLen_Min=5
GetNbrLen_Max=5
Confirm=ON
VbScript=
VbsHoldPlay=
on {success} goto [ConfirmID]
on {timeout 2} goto [Hangup the Call]
Position=58,156
[ConfirmID]
Type=Play
DispSize=69
Txt="Please press 1 if that's correct, or press 2 to re-enter."
Replay=0,0
strTtsText=
on {timeout 0} goto [Save Data to File VBS_7]
Position=58,260
[ThankA]
Type=Play
DispSize=69
Txt="Thank you.  Goodbye."
PlayFile1=saystdbye.wav
Replay=0,0
strTtsText=
on {success} goto [Hangup the Call]
Position=192,488
[Hangup the Call]
Type=Hangup the Call
DispSize=69
Txt=Hangup the call.
Position=445,536
Type=Run VB Script
DispSize=69
Txt=Save entered data to a file using VBScript
VbsFileToRun=
VbsWait=1
VbScript=
If $RV_HH > 12 Then
Else
End If
tsFile.Close
set fso = Nothing
VbsHoldPlay=
on {success} goto [ThankA]
on {fail} goto [ThankA]
on {timeout 0} goto [ThankA]
Position=63,365
[OLD Save Data to File_18]
Type=Run Program
DispSize=69
Txt=Echo the entered data to a file. This DOS Command line  approach will result in the saved data being mangled if more the one line writes to the file at precisely the same time.
ProgramToRun=command.com /c echo $RV[GetID] >> c:\Program Files\VoiceGuide\Scripts\Meter Reading\IVRAttendence.txt
RunHoldPlay=
RunMode=1
RunWait=1
Position=286,362
[Check Caller ID]
Type=Evaluate
DispSize=69
Txt=Evaluate the Result Variable specified, and select the path which matches the current value of the Result Variable
Expression="$RV_CIDNUMBER"
ExprNewRV=
ExprStoreRV=0
ExprStoreInGlobalRV=0
on {true} goto [Get Lang]
on {Private} goto [Play 2]
on {OUTOFAREA} goto [Play 2]
on { } goto [Play 2]
Position=325,15
[Play 2]
Type=Play
DispSize=69
Txt=Play a sound file, then await a response...
PlayFile1=C:\Program Files\VoiceGuide\System\Voice_1\beep1.wav
Replay=0,5
strTtsText=
on {timeout 2} goto [Save Data to File VBS_1]
Position=563,226
Type=Run VB Script
DispSize=69
VbsFileToRun=
VbsWait=1
VbScript=
set tsFile = fso.OpenTextFile("c:\Program Files\VoiceGuide\Scripts\Meter Reading\IVRPrivate.txt", ForAppending, True)
If $RV_HH > 12 Then
Else
End If
tsFile.Close
set fso = Nothing
VbsHoldPlay=
on {timeout 0} goto [Hangup the Call]
on {fail} goto [Hangup the Call]
Position=595,378
In the same 'Run VBS' module (module is: "Save Data to File VBS_7")
The entire quoted script from our post goes in the same one module.
Dear Sir
I have already send mail , BUT , Can I send different email address according to (GET ID ) staffs ?
Yes. You can use a Result Variable for the "To:" destination field, and set that $RV to any email address(es).
Probably easiest to use an Evaluate Expression module to set the $RV:
https://www.voiceguide.com/vghelp/source/html/modevalexpr.htm
Have one Evaluate Expression module set $RV[dest_email] to one value and have another Evaluate Expression module set $RV[dest_email] to another value etc. Then have script run one module or another before calling the Send Email module, and in Send Email module use $RV[dest_email] in the "To:" field.
More information on Result Variables:
https://www.voiceguide.com/vghelp/source/html/resultvariables.htm
Send Email module:
https://www.voiceguide.com/vghelp/source/html/modsendemail.htm
