$rv_cidnumber Missing
I used to be receiving Caller ID info, but then after I have successfully fixed the 'hangup' detection problems by changing the disconnect frequencies, somehow (co-incident or not) I find that I can no longer detect Caller ID, which always returned as blank. I have set the Line Config to pick up the call after even 4 rings (previously I only need to set it to 2 to detect Caller ID)
Kind advise what could have happened. Thanks! (The event log is attached beneath.)
215807.31 6 linedevstate 2048 0 0
215807.31 6 callstate OFFERING 65605 0 4
215807.33 6 callinfo CALLEDID
215807.33 6 callinfo ORIGIN
215807.33 6 ring 0
215813.33 6 ring 2
215819.33 6 ring 3
215825.34 6 ring 4
215825.34 6 Start without answering the call
215825.34 6 StartLoadedVgs at 16/3/2004 21:58:25
215825.34 6 rv add [$RV_STARTTIME]{16/3/2004 21:58:25}
215825.34 6 rv add [$RV_DEVICEID]{6}
215825.34 6 rv add [$RV_CIDNAME]{}
215825.34 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
215825.34 6 rv add [$RV_CIDNUMBER]{}
215825.34 6 TimeoutClear
215825.34 6 [Call Alert] Running VB Script...
215825.34 6 RVreplace start: ['Script : Call Recorder.vgs
'Module : Call Alert
if msgbox("Number : $RV_CIDNUMBER" & vbCrLf & "Name : $RV_CIDNAME", vbYesNo + vbQuestion , "Record Call ?") = vbYes then
vg.Run_ResultReturn $RV_DEVICEID, "yes"
else
vg.Run_ResultReturn $RV_DEVICEID, "no"
end if
set vg = Nothing
215825.34 6 RVns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{16/3/2004 21:58:25}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}
215825.38 6 Run Script waiting... (shellid=2776, process=1248)
215825.38 6 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
215826.38 6 Timer fired EV_TIMEOUT_CHECKONSTATE
215826.38 6 ScriptEventCode 9007 iLineState=1501
215826.38 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
215826.38 6 task still running (shellid=2776, process=1248)
215826.38 6 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
215827.47 6 Timer fired EV_TIMEOUT_CHECKONSTATE
215827.47 6 ScriptEventCode 9007 iLineState=1501
215827.47 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
215827.47 6 task still running (shellid=2776, process=1248)
215827.47 6 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
215827.66 6 cl Run_ResultReturn >>no<<
215827.67 6 rv add [Call Alert_ResultReturn]{no}
215827.67 6 TimeoutClear
215827.67 6 rv add [Hangup Time]{16/3/2004 21:58:27}
215827.67 6 Hanging up call... [Hangup Module]
215827.67 6 HangupCall_Common Mode=BeforeAnswerRun
215831.34 6 ring 5
215837.34 6 ring 6
215838.75 6 linedevstate 2048 0 0
215838.75 6 callstate IDLE 65605 0 0
215838.75 6 WorkingMode@Idle=
215838.75 6 TimeoutClear
215838.77 6 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
215839.83 6 Timer fired EV_TIMEOUT_TIMETOREINITLINE
215839.83 6 ScriptEventCode 9008 iLineState=900
215839.83 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
215839.83 6 ReinitTelephony due to IDLE
215839.83 6 tapic lineDeallocateCall(MainCall:65605) 0
215839.88 6 lineOpen(6)=>
215839.88 6 Waiting for a call...
215839.88 6 LineHandle=66237
215839.88 6 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
215843.16 6 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
215843.16 6 ScriptEventCode 9013 iLineState=900
215851.83 0 sys cleanup Start
215851.83 0 sys cleanup End
Setting the disconnect tone frequencies/cadence does not affect the receiving of CallerID information.
Have you tried attaching a CallerID monitoring device to this line to see if the phone company is sending CallerID on this line at all?
Yes, I used a phone and the Caller ID did display correctly between the 1st and 2nd ring. Also, as I mentioned, it used to display correctly before my upgrade to 5.2.1 (don't know if the different version makes a difference).
Please help. Thanks!
The trace shows that the telephony device is not reporting any Caller ID information to VoiceGuide.
What telephony device are you using? (Dialogic?)
Not too sure why a D/4PCI would stop reporting caller ID information.
I'd probably try uninstalling all Dialogic drivers (entire 'System Release') and installing all again.
