Cisco Call Manager Configuration
5. Fax
6. Voicemail
7. Outbound Dialing
Outbound VoIP calls
External Database Source (v7)
8. Speech Recognition
9. Logs
10. ActiveX / COM Interface
11. PBX Integration (CTI)
Creating Grammars
MrcpV2 severs can accept grammars in both the ABNF and the GrXML format. Both notations are part of the SRGS standard.
Introductory information on grammar design can be found at this location if the LumenVox speech recognition engine is installed:
Start -> Programs -> LumenVox -> Engine -> Documentation -> LumenVox SDK Help
See section titled Grammars.
Some introductory grammars are also provided with the SpeechRecogntionDemo VoiceGuide scripts.
Further Reading:
Speech Recognition Grammar Specification Version 1.0
http://en.wikipedia.org/wiki/Speech_Recognition_Grammar_Specification
Converted from CHM to HTML with chm2web Pro 2.84 (unicode)
